    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 06-06-2026 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    will do. Still waiting for other parts to arrive
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    dudz's Avatar
    How thick can I go with the aluminium bed ? (using a silicone heater of 900W 230V). The full size of the Aluminium is 470mm by 300mm. I have a 3mm piece but the span seems to large for 3mm. Can I go 5 or 6mm ? It will only be supported in the corners
    There are few (or none) printers that use a 470mm long bed supported at the corners only. The reason is the aspect you mentioned yourself, you have a 470mm long sheet of aluminium supported at the ends only. There will definitely be some deflection at the middle of that length. If your deflection is 0.1mm and you are printing 0.1mm layers, you have a deflection of one full layer thickness at that spot. It can be suppressed by using a raft or setting a thicker first layer in your slicer, but you will soon find these methods inconvenient.
    I would assume a 5mm aluminium thickness would be required, but it also depends on the aluminium alloy in terms of stiffness. You will probably have an extra sheet of glass/mirror/borosilicate on top of it, which will be your actual printing surface. The extra glass layer will tend to remove the deflection. However, even so, if in theory the glass manages to keep its straightness while the aluminium is slightly bent at the middle, the missing contact surface will mean less heat conductivity.
    All printing surfaces over 300mm I have built were not supported by the 4 corners method. 3 parallel beams were laid under the bed - one on each side and one at the middle. No springs were used and during calibration the beams were shimmed under after checking the surface with a dial indicator.
    Silicone heaters are effective but more dangerous then the usual 12V/24V stuff. I would add a thermal fuse or two under that bed.
  5. The Following 2 Users Say Thank You to Trispectiv For This Useful Post:
  6. #5
    dudz's Avatar
    Thanks. Very helpful. I did think about supporting it more or less the way you suggested, but I am paranoid about supporting underneath the silicone heater (I dont know how much stress the silicone heaters will stand). Because It is a CNC machine, the bed will be put on and taken off when I need to mill, so I need to make it as easy as poss
  7. #6
    Silicone heaters should sustain the stress we are talking about here, but since yours goes directly into the wall plug, I would avoid giving any bright advice about the setup - if something goes wrong, it can cause major damage.
    If you don't wish to use the 3 beams method, you could then use 2 beams on the long 470mm side. This way you would have to worry about the bending on the small 300mm side only. With no central beam, the silicone heater will not be mechanically stressed. Beams will also replace the springs, which in my opinion are not a good choice for anything larger then 200x200. You could use spring washers or shims under the beams instead, to perfectly level the beam ends (which represent the 4 corners). Common 10x20 or 20x20 Profile 5 extrusions from Misumi/item/Rexroth are perfect candidates for the beams. Or you can just craft your own if you having a good fly cutter or rectifier machine.
    A method for switching between setups is kinda hard to suggest since I am not familiar with your machine. You will probably have some bolting spots near the center of your current router table.
  8. #7
    dudz's Avatar
    The heater is controlled via PID temp controller using a Thermocouple. Your supporting suggestions sound good. I will plan around this idea.
  1. Advice needed on Amadeal
    By croy in forum General Discussion
    Last Post: 21-08-2015, 01:28 PM
  2. What's needed for a 3d printer build??
    By Davek0974 in forum 3D Printing Machines
    Last Post: 18-02-2014, 11:54 AM
  3. Quick Advice Needed - F&S
    By Tenson in forum Tool & Tooling Technology
    Last Post: 01-01-2013, 06:38 PM
  4. RFQ: Looking for member with water cutting ability
    By m.marino in forum Projects, Jobs & Requests
    Last Post: 06-07-2011, 03:30 PM
  5. SPG X3 CNC Mill, advice needed please
    By shaggyhawkings in forum Milling Machines, Builds & Conversions
    Last Post: 07-01-2010, 11:00 PM
