Thread: Small 3D Engraving
01-01-2015 #1
This is a product stamp I made last year for a friend, it's on 10mm diameter tool steel rod, hardened & tempered after engraving and relieving the excess material around the stamp outline on the grinder -
This is what it does on hot steel plate -
It took some time to develop the engraving spindle setup on the mill, this 3D job was performed with no depth guide and the spindle slide mount fixed, not sprung, a depth guide can be added for fixed depth work on nominally flat or fairly smooth 3D surfaces. The rig can be used without rotation for Diamond Drag Engaving down to about 1mm text height.
This was the setup for my first experiment with a 4-Axis engraving job, it just reads "TEST ENGRAVING" around a 20mm Stainless Steel bar
Somewhat simplistic but it pleased me, the bar is still on a shelf somewhere ;-)
- NickLast edited by magicniner; 01-01-2015 at 02:29 AM.
01-01-2015 #2
Nice engraving, I like your spindle speeder do you a thread on this site about its construction?
CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
01-01-2015 #3
That die looks great - very impressive - (pun intended). Well done. G.
RFQ: Small sized Parts need making, small batches
By Ptee in forum Projects, Jobs & RequestsReplies: 3Last Post: 17-01-2014, 06:07 PM -
RFQ: Wood Sign/engraving required, small job one off money waiting...
By njhussey in forum Projects, Jobs & RequestsReplies: 8Last Post: 21-09-2013, 07:12 PM -
NEW MEMBER: engraving
By pontinal in forum New Member IntroductionsReplies: 3Last Post: 11-05-2012, 01:02 PM -
Engraving pictures
By Kai in forum Computer SoftwareReplies: 1Last Post: 19-07-2011, 09:49 PM -
PCB Engraving / Cutting
By jrob3rts in forum General DiscussionReplies: 6Last Post: 02-06-2011, 09:35 PM
