Thread: Text in G-code File
Charlie It's the [ ] causing problem use ( ) but you'll probably need to modifie the post processor to change this Or some software will have options in the post/G-code output section that let you select how comments are output.
04-01-2015 #2
cheers yes it sorted the problem, it was in a file that the main code got put in. I have found another move in the main code that it likes to do that I would like to change but Im guessing that is out side of my control other than to manually edit it after. (it is right in the last two lines of coordinates were it moves in a diagonal rather than just up and across out of the block)
Free Engraving Software (Text to G-Code)
By Musht in forum CAD & CAM SoftwareReplies: 4Last Post: 14-08-2014, 01:04 PM -
Raised Text
By petesos in forum CAD & CAM SoftwareReplies: 6Last Post: 02-04-2013, 11:21 AM -
File upload problems - attachments file extension support !
By Swarfing in forum General DiscussionReplies: 14Last Post: 08-03-2013, 02:37 PM -
green text
By blackburn mark in forum General DiscussionReplies: 13Last Post: 25-07-2012, 05:30 PM
