08-01-2015 #6
Here and there you could do cheap. But if i were you, Nema 23 motors and profile rails like hiwin, new or used from ebay, these 2 are a must.
On such a small machine you actually need 4 rails, 2 left right, gantry, Z. Yeah, the Z will work ok with even 1 proper rail. With spindle 0.8kw i mean, no bigger.
Moving table and fixed gantry will even give further possibility to your build.
You could perfectly make the machine using belts without problem, though the 3 ball screws for that machine will be like 150. So not so much.
Having a drill is a must.
So if you are clever you could build a beauty on a budget. Spend more time designing and considering and less money wasted.
Don be shy from steel, cause thats the cheapest way to go. You will spend how much , 50-70 for the steel.
Better dont be in a rush, buy when you can and build slowly something that can make you money.
Or if you want your hair to be white soon, do a crappy machine that will make you swear every time you look at it.
BUILD LOG: Need some final decisions before start building…
By msacnc in forum DIY Router Build LogsReplies: 5Last Post: 22-09-2014, 11:22 PM -
Making a little box
By mark84 in forum General DiscussionReplies: 5Last Post: 11-03-2014, 11:34 PM -
Mold Making?
By Shinobiwan in forum Moulding MachinesReplies: 10Last Post: 27-02-2013, 02:15 AM -
Looking for tips on making 2.5 x 1.25 mtr table
By psiron in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 14-06-2010, 08:09 PM -
Making a Jig
By Wobblybootie in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 06-06-2010, 11:17 AM
