Thread: G53 movement
    Should the G53 be before or after a G00 or G01 command ?
    LinuxCNC has it before:
    "For example G53 G0 X0 Y0 Z0 will move the axes to the home position even if the currently selected coordinate system has offsets in effect."
    Mach 3 has it after:
    "For linear motion to a point expressed in absolute coordinates, program G1 G53 X~ Y~ Z~ A~ B~ C~ (or similarly with G0 instead of G1),"
    After makes more sense, as both say it has to have G00 or G01 "active" to work.
    Off to the workshop to try it.
    Adrian
    I just tried it with Mach3 and it works either way round. I only tried with G0
    Lives in Plymouth, United Kingdom. Last Activity: 22 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I think that it comes down to whatever the motion control software accepts! However, it does seem that gcode is a bit flexible about this kind of thing. For example, you can put the coordinates in in any order, and I have a feeling that the G53 can be anywhere on the line. From memory, I think I use G0 G53 X~ Y~ because that seems logical to me, but I don't think it matters. That's all true for Mach3 and LinuxCNC, anyway, but some of the proprietary motion control systems might have their own interpretation.
    Thanks both, I'll try my program the other way round and see if it makes any difference.
    There are other things at play, so this might be a red herring.
    Adrian.
  1. axis movement jamming
    By Skydeals in forum Linear & Rotary Motion
    Last Post: 18-12-2014, 10:27 AM
  2. funny movement on solidcam turning
    By eamo1978 in forum Solidworks
    Last Post: 23-06-2014, 08:16 AM
  3. Z axis assembly - unsupported rail for very limited movement
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 10-10-2012, 12:44 PM
  4. Motors, pulleys & movement - not strictly CNC related...
    By Rogue in forum General Discussion
    Last Post: 20-09-2011, 11:05 PM
