    Not impossible to make a perfect gantry from the same profile/60x60./ I just said bigger, cause of the hiwin carriages bolt distance, cause the best would be to make the gantry sides from profile.
    Draw something, i also have some ideas about the gantry from 60x60.
    Just an update on available box section
    50 x 50 3mm wall
    60 x 60 4mm wall
    80 x 40 3mm wall
    Could I get away with welding 2 80 x 40 box section together to make the 80 x 80 gantry ?
    Would the weight be too much for stepper motors ?
    thanks
    if i was making it i would use 3x 80x40x3 for the gantry. Arranged in L or arranged in ], /where z is left side of symbols ,gantry looked from right side of the machine/
    Cause if only 2x arranged in | , i dont like that the width will be only 40mm, quite bendy to my liking, when machine is cutting front back direction. But if aluminum is not the main idea, some compromise could be made here.
  2. Small Gantry Router
    By mike os in forum Gantry/Router Machines & Building
    Last Post: 08-01-2015, 07:02 PM
  3. RFQ: RQF: Router Gantry plates
    By lateAtNight in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 04:56 AM
  4. Looking for some help designing my gantry please
    By psiron in forum Gantry/Router Machines & Building
    Last Post: 05-07-2010, 09:52 PM
  5. BUILD LOG: Fixed Gantry Router
    By lateAtNight in forum DIY Router Build Logs
    Last Post: 28-05-2009, 11:30 PM
