    AXYZ 6010 3x2 meters Great condition, Must See!!!
    Gerber System 48 Plus CNC Router For Sale
    Thats Cheap especially if you want full solution. So you can start right away making money.
    There's no prices on any of those machines Boyan so how do you work out they are cheap.?
    Locust.
    Problem is that at the size you want and with the type of material you want to cut then you'll most likely need vacuum to hold down material.
    High volume vacuum pumps are not cheap esp for the size your wanting so trying to do this on a budget will be difficult.
    The machine required for your needs could be built resonable enough but a good vacuum system could cost nearly the same amount.!
    Sorry mistake, i was assuming they could be had for cheap when you have the cash in the pocket, as they seem complete solution. Anyway, the prices for second hand machines like these are quite clear, at least to me and as you say building it could cost almost the same, with the addons for production i mean.
    Hi Locust
    I imported mine, it's a 1325 machine that easily takes a full 8x4 sheet have cut mdf, ply, foamboard thin plate, hardwood so far. With the purchase plus cargo, import duty and vat it cost me around 7000 Euros. Came with 3hp 4 bag dust collector and choice of control system. I got the DSP very easy to use, does all that I need it to.
    Good luck
    Alan
  6. The Following User Says Thank You to alboy For This Useful Post:
  7. #5
    Thanks everyone for your replys, most helpful..
  8. #6
    Quote Originally Posted by alboy View Post
    Hi Locust
    Good luck
    Alan
    do you have a link to this machine ? thanks
  9. #7
    HI Locust have PM'd you.
    Al
  1. wood sign cut with cnc router
    By jonm in forum Woodworking Project Showcase
    Last Post: 09-06-2014, 08:05 PM
  2. Looking for advice on budget machine for watchmaking
    By lanky_streak in forum Marketplace Discussion
    Last Post: 25-09-2013, 10:59 AM
  3. My first sign
    By Web Goblin in forum Metalwork Project Showcase
    Last Post: 03-04-2013, 09:05 PM
  4. NEW MEMBER: IT/Sign Maker/Geek
    By daverowland in forum New Member Introductions
    Last Post: 12-07-2012, 10:07 PM
  5. New to CNC: Best way to generate the g-code for this sign
    By drphil in forum Computer Software
    Last Post: 07-03-2012, 09:35 PM
