  1. #7
    I made some test jig from wood. Works perfectly.
    One thing is clear to me now. All hosing from compressor up to the CNC must be industrial 1/4 or 3/8, cause i will step on it, solder over it and so on. It must be strong so no cheap PVC hoses here. Added bonus is that i use the same hoses and extensions like for air. So the only thing i bought is the 3/8 quick connector which i fitted at the compressor inlet side.
    Decided to save on connectors :-) so i drilled the vacuum fixture and just pushed the PVC hose inside, it works perfectly. Recessed all the necessary areas 3mm. Drilled hole to the back so the vacuum fixture is self fixing to the table. Hole could be closed and instead fixture clamped.
    The mat is non slip mat from chinese shop -2euro. 15mm wide rings, i wanted a superb friction.
    Next step will be when i have time to fit the Vacuum switch to the compressor, check the negative pressure achieved and test if using vacuum reservoir/the compressor tank/ is better in any way.
    Video : https://plus.google.com/111571569713...ts/BHSTDvFBjks
ID:	14428   Click image for larger version.
ID:	14431   Click image for larger version.
ID:	14432   Click image for larger version.
ID:	14430   Click image for larger version.
  1. I want a vacuum table!
    By Tenson in forum Machine Discussion
    Last Post: 08-01-2014, 07:40 PM
  2. vacuum table using compressed air
    By plasticman in forum Milling Machines, Builds & Conversions
    Last Post: 25-12-2012, 05:42 PM
  3. Vacuum Table Advice
    By Minium in forum Milling Machines, Builds & Conversions
    Last Post: 13-11-2012, 09:52 AM
  4. Vacuum Tables
    By Chris J in forum Milling Machines, Builds & Conversions
    Last Post: 04-05-2012, 01:58 PM
  5. DIY Vacuum Table
    By templecorran in forum Machine Discussion
    Last Post: 10-11-2010, 12:11 AM
