Thread: DIY Vacuum Fixtures
16-01-2015 #10
No, but it seems is not necessary. Its very dense. I made it from wood as a test to understand better how it works, before making some stuff in aluminum. It seems though it will perfectly work if wooden. it made from a solid kitchen cutting board. however sealing it is recommendable, due to humidity so it would not twist when dry or humid
it will suck probably more air from the actual part, which is has 3mm bottom /pine/
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
vacuum table using compressed air
By plasticman in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-12-2012, 05:42 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Vacuum Tables
By Chris J in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 04-05-2012, 01:58 PM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
