Page 1 of 4 123 ... LastLast
    I have looked at great length for a square headed bolt like this.
    I comes out of a Kity 635 planner thicknesser which I am due to sell due to lack of space. I only want £175 for it I could stick it on a pallet if it helps
    I am not expecting anyone to know where I can get one but thought it worth a try as I don't want to replace all the bolts.
    Bolt size 9.9mm square head
    M6 thread
    15mm overall length
    I have tried Sheppach.com and NMA agencies but no joy.
    Many thanks if anyone knows where to try.
    All the best
    Suesi
    Could you cut and file a square piece of steel the same size as the head then drill and tap an M6 hole in it and screw & glue a piece of studding in ? A flash over with matt black paint would finish it off.
  3. The Following User Says Thank You to EddyCurrent For This Useful Post:
    Hi EddyCurrent,
    Thank you for your reply that was quick to come up with that. I guess I could go with your idea if I cant get a bolt. I was thinking of replacing the bolts to all hex head but it seems a bit wasteful. I guess they want to high tensile due to the stress on them.
    Hope your project is coming on it sure looks great.
    Many thanks
    Suesi
  5. #4
    It was just a guess because I didn't know what they did on the machine.
    Re. my project, it's finished, the thread shows all there is to know, I just need to make something with it now. Next I need to do mortice & tenon, fancy dovetail types but not the regular dovetail shape.
  6. #5
    Silly me mate not mentioning what the bolt does! I holds a cutter wedge.
    Yes, I think the cut out in the table is great, I can see it being very useful. I look forward to hearing what you make.
    All the best
    Suesi
  7. #6
    I knew you were going to say it holds the cutter wedge, it's similar to mine and the first thing that came to mind when I saw it. In that case I would try to get something better than my first idea.
  8. #7
    Yes, sorry my fault for missing the most important detail!
  9. #8
    i2i's Avatar
    make one, you have the machines
  10. #9
    I don't know about that!
    Yes, I have a mill but not the software and to say I am finding my feet with it is an understatement. It is that old thing of we all start somewhere. I set eyes on an old whitworth bolt the other day that made me think knowing it was good material.
    Cheers Suesi
  11. #10
    bit of sq stock in a 4jaw on a lathe. turn it down then thread it ?
  12. The Following User Says Thank You to T0rnado69 For This Useful Post:
  1. Website idea.
    By qwertyjon in forum General Discussion
    Last Post: 11-07-2014, 08:49 PM
  2. WANTED: bolt on rail and block bearings or what ever - what have you
    By nobby in forum Items Wanted
    Last Post: 13-05-2014, 10:22 AM
  3. Here's an idea hacking a Kress 1050 FME
    By m.marino in forum Kress Milling Motors
    Last Post: 16-01-2013, 01:05 AM
  4. Machine bed T bolt
    By Colin Barron in forum Gantry/Router Machines & Building
    Last Post: 02-10-2010, 11:20 PM
  5. BUILD LOG: Mel's Odd Idea
    By mel_earp in forum DIY Router Build Logs
    Last Post: 19-03-2010, 11:54 AM
