make one, you have the machines
11-01-2015 #2
I don't know about that!
Yes, I have a mill but not the software and to say I am finding my feet with it is an understatement. It is that old thing of we all start somewhere. I set eyes on an old whitworth bolt the other day that made me think knowing it was good material.
Cheers Suesi
11-01-2015 #3
bit of sq stock in a 4jaw on a lathe. turn it down then thread it ?
The Following User Says Thank You to T0rnado69 For This Useful Post:
11-01-2015 #4It would need to be the same weight to balance the others if it is on the cutter block.Silly me mate not mentioning what the bolt does! I holds a cutter wedge.
11-01-2015 #5
If it's retaining your planer blade you are going to need it making from a decent piece of steel, if Kity don't do spares i would do as per Tornado69 post but not quite sure regarding the tensile strength of MS square stock, to be on the safe side i would get an oversize Unbrako bolt and machine from that, the Unbrako fasteners i have used in the past are very tough.
Hope that helps
Mike
The Following User Says Thank You to mekanik For This Useful Post:
11-01-2015 #6
Hi mekanik
Thank you for your msg. I had never heard of Unbrako fasteners but just looked on the site they are obviously good stuff. I think I will contact them to see what they do square head wise before getting one made. I see they used to do some!
http://www.ebay.co.uk/itm/2709194450...%3AMEBIDX%3AIT
Many thanks Suesi
11-01-2015 #7
Hi Clive,
Thank you for your msg. Yes it would have to be pretty close for weight I know the importance of balance many years ago I ground by hand cutters for the old whitehill blocks. Not one of my favourite jobs!
Many thanks Suesi
11-01-2015 #8
I've still got scar from one those lethal bastards.! . . Cutter let go skimmed my belly and embedded it's self in wall. My mate wasn't so lucky when is let go embedded it's self in his thigh.!! . . Messy job.
Think your only option if Kity won't reply is to make one then heat treat it. Will need good grade of steel or bolt if you modifie something.!Last edited by JAZZCNC; 11-01-2015 at 05:12 PM.
11-01-2015 #9
This seems to be the mostly likely place to get Kity spares, but people say drive belts are about the only thing available.
http://www.kitystc.eu/index.phpSpelling mistakes are not intentional, I only seem to see them some time after I've posted
The Following User Says Thank You to EddyCurrent For This Useful Post:
11-01-2015 #10
It's illegal to use Whitehill blocks now. If H&S catch you using them, you'll have an awful lot of explaining to do.
Any blades now have to have a pin/bolt that passes through the blade so it can't just fly out as soon as it slackens off, or be of a design where it can't come out just by being loose.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Website idea.
By qwertyjon in forum General DiscussionReplies: 18Last Post: 11-07-2014, 08:49 PM -
WANTED: bolt on rail and block bearings or what ever - what have you
By nobby in forum Items WantedReplies: 8Last Post: 13-05-2014, 10:22 AM -
Here's an idea hacking a Kress 1050 FME
By m.marino in forum Kress Milling MotorsReplies: 3Last Post: 16-01-2013, 01:05 AM -
Machine bed T bolt
By Colin Barron in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 02-10-2010, 11:20 PM -
BUILD LOG: Mel's Odd Idea
By mel_earp in forum DIY Router Build LogsReplies: 3Last Post: 19-03-2010, 11:54 AM
