It's illegal to use Whitehill blocks now. If H&S catch you using them, you'll have an awful lot of explaining to do.
Any blades now have to have a pin/bolt that passes through the blade so it can't just fly out as soon as it slackens off, or be of a design where it can't come out just by being loose.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
11-01-2015 #2
11-01-2015 #3
Thanks m_c I don't use a spindle anymore but I went over to euro and serrated blocks long ago and I can't say I miss hand grinding cutters! They did get me out of a fix a few times for just a quick simple run. Thanks very much suesi
11-01-2015 #4
If you can't make it yourself make sure it is made from height tensile steel, also take a sample and tell them to reproduce the radius were the dia meets the square, if this is done with a sharp tool it will produce a stress raiser.
Regards
Mike
The Following User Says Thank You to mekanik For This Useful Post:
11-01-2015 #5
if you know the material that the bolt is made of turn and thread one 14mm diameter then put the square on, the formula is 1.414 x across flats for the dia of a square, this should also be about the same weight if this cant be done I could knock you one up at work out of en8 or 19t
The Following User Says Thank You to bmbaz For This Useful Post:
12-01-2015 #6
Dear bmbaz,
Many thanks for your help and offer to make me a bolt if I get stuck. I understand the 1.414 side of things. If I take you up on your offer please let me know what I owe you and I will pay you.
Many thanks
Suesi
12-01-2015 #7
Hi mekanik,
Thank you for you msg. I can't make one myself. However, I can tell what you are telling me is important although I am sorry I do not understand what you mean by "tell them to reproduce the radius were the dia meets the square" I could learn this I think it could be doing. You say if that is done with a sharp tool it will produce a stress raiser, so is there a time when a blunt tool is better?
Many thanks for the help
Suesi
13-01-2015 #8
No, it means use a sharp tool, but with a rounded tip rather than a sharp angle at the tip. That would leave a radius in the corner rather than a square corner, which is good from a stress-reduction point of view. Any sharp change in dimension concentrates the stress at that point. It's very seldom better to use a blunt tool for anything!
The Following 2 Users Say Thank You to Neale For This Useful Post:
13-01-2015 #9
Hi Neale
Many thank for your msg. I see what your saying and understand now.
I appreciate the help
Suesi
13-01-2015 #10
Suesi
Dia is an abreviation for diameter ie 6mm the radius is formed where the diameter intersects the square section (like head of a bolt) when a bolt is torqued it actually increases slightly in length and loads the assembly,if there is a sharp junction a crack can propergate in that area especially if the item was subject to and impact. The radius helps to distribute the load, some of the guys on the forum have the software that can show stress analysis.
As for the cutting tool,NO there is no time when a blunt tool is preferable to a sharp one (to the best of my knowledge), in this case you would just produce a slight radius on the tip of the tool still maintaining the correct clearance angles. hope that makes some sort of sense.
Regards
MikeLast edited by mekanik; 13-01-2015 at 12:15 AM.
Website idea.
By qwertyjon in forum General DiscussionReplies: 18Last Post: 11-07-2014, 08:49 PM -
WANTED: bolt on rail and block bearings or what ever - what have you
By nobby in forum Items WantedReplies: 8Last Post: 13-05-2014, 10:22 AM -
Here's an idea hacking a Kress 1050 FME
By m.marino in forum Kress Milling MotorsReplies: 3Last Post: 16-01-2013, 01:05 AM -
Machine bed T bolt
By Colin Barron in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 02-10-2010, 11:20 PM -
BUILD LOG: Mel's Odd Idea
By mel_earp in forum DIY Router Build LogsReplies: 3Last Post: 19-03-2010, 11:54 AM
