12-01-2015 #5
As a first approximation, yes the spindle will draw more current as the load increases. The problem is the motor efficiency changes with load and speed, so it's tricky to estimate the actual torque output, though not impossible. If you subtract the no-load current from the current whilst cutting, that's a good start. But if you're more interested in not overloading the spindle, then just looking at the phase current as a proportion of the rated current is sensible.
I'd almost forgotten about that thread discussing linking torque to feedrate, but I've got a bit further with my motor drive I will use in it so it wont be too long now.Last edited by Jonathan; 12-01-2015 at 01:15 PM.
metric thread dial indicator
By Raymond in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 12-06-2014, 08:10 PM -
Help with Supply Indicator Lights
By GTJim in forum General ElectronicsReplies: 7Last Post: 03-09-2013, 08:49 PM -
pulley fit on motor shaft - force it on?
By dsc in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 09-08-2013, 06:11 AM -
Co axial centering indicator
By Robin Hewitt in forum Tool & Tooling TechnologyReplies: 13Last Post: 03-02-2012, 07:49 PM -
Drilling force monitering/chipped drill detection/1000's of holes in SS
By PatK in forum Tool & Tooling TechnologyReplies: 3Last Post: 27-09-2011, 11:57 PM
