Thanks Jonathan. Call it cheap thrills but I'm basically looking into some interesting little future enhancements to make to my router once I have it working to keep me occupied. I'll play around a little to see what the no load current looks like at different frequencies and take it from there. Until my spindle is actually cutting something, is there a safe way to put some load on to see what happens to that current output? The though had crossed my mind to put a thick glove on and gently apply pressure to the collet nut but I'm way too scared to be the first guy to try that :-)
Your plan of automatically varying the feed rate or spindle speed sounds like a very cool idea or maybe even just to do a estop when it figures out its about to break a certain size cutter or stall the spindle but I'll have to learn quite a bit more before I can join in on that fun :-)
12-01-2015 #2
If you're keen you could take several readings, graph them then use that as a look-up table or function to subtract from the on-load current in software, on an Arduino (or similar), then connect a display... In fact you could do it quite easily with an Arduino, current sensor and display:
http://www.ebay.co.uk/itm/New-Blue-I...item3f3eb02c30
http://www.ebay.co.uk/itm/Range-ACS7...item565bbee604
You wouldn't be the first ;)
12-01-2015 #3
Arduino. Yep those are very high on my list of things to toy with, just wasn't sure what I'd use it for but now I have a plan!
Sorry last stupid question. Using this approach with that sensor would I measure current on then single phase input side of the vfd or on the output side or does it even matter?
12-01-2015 #4
12-01-2015 #5
13-01-2015 #6
@Jonathan: Ok, thanks, that makes sense.
@Eddie: Thanks, I'll give that a go. My fingers is getting older so they so they don't grow back as quick as they used to :-)
Not sure but I think I read somewhere the peak torque of these 2.2kw watercooled spindles is something like 0.8nm. Does anybody have a rough idea what the torque curve for these looks like?
metric thread dial indicator
By Raymond in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 12-06-2014, 08:10 PM -
Help with Supply Indicator Lights
By GTJim in forum General ElectronicsReplies: 7Last Post: 03-09-2013, 08:49 PM -
pulley fit on motor shaft - force it on?
By dsc in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 09-08-2013, 06:11 AM -
Co axial centering indicator
By Robin Hewitt in forum Tool & Tooling TechnologyReplies: 13Last Post: 03-02-2012, 07:49 PM -
Drilling force monitering/chipped drill detection/1000's of holes in SS
By PatK in forum Tool & Tooling TechnologyReplies: 3Last Post: 27-09-2011, 11:57 PM
