    Quote Originally Posted by mitchejc View Post
    The though had crossed my mind to put a thick glove on and gently apply pressure to the collet nut but I'm way too scared to be the first guy to try that :-)
    With motors the general method was to jam a piece of 3 x 2 against the rotating shaft to act as a brake, you want it so the shaft is trying to pull the wood from you.
    @Jonathan: Ok, thanks, that makes sense.
    @Eddie: Thanks, I'll give that a go. My fingers is getting older so they so they don't grow back as quick as they used to :-)
    Not sure but I think I read somewhere the peak torque of these 2.2kw watercooled spindles is something like 0.8nm. Does anybody have a rough idea what the torque curve for these looks like?
  1. metric thread dial indicator
    By Raymond in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 12-06-2014, 08:10 PM
  2. Help with Supply Indicator Lights
    By GTJim in forum General Electronics
    Last Post: 03-09-2013, 08:49 PM
  3. pulley fit on motor shaft - force it on?
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 09-08-2013, 06:11 AM
  4. Co axial centering indicator
    By Robin Hewitt in forum Tool & Tooling Technology
    Last Post: 03-02-2012, 07:49 PM
  5. Replies: 3
    Last Post: 27-09-2011, 11:57 PM
