Thread: Boxford 160TCL to Mach3
13-01-2015 #4
you can get a good working machine for very little expense by using the existing drives, power supply and steppers. You can get this within the constraints of a single parallel port even with the atc if fitted. The existing power supply and drivers will run the steppers well, but if you need more performance, more powerful drivers and a larger power supply will be needed. What you need to decide is what you want from the 160 and even if you need greater performance.
Boxford vmc260 to mach3 conversion
By jamesgates1000 in forum Boxford Vertical MillsReplies: 22Last Post: 30-01-2020, 11:47 PM -
CONVERSION: boxford vmc 300 mach3 conversion
By bigred5765 in forum Conversion Build LogsReplies: 14Last Post: 05-07-2018, 06:05 PM -
Boxford VMC 190 to Mach3 questions
By swood1 in forum Boxford Vertical MillsReplies: 3Last Post: 08-08-2014, 09:40 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM
