Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by mike os View Post
    removal the same way?
    Yes it is.
  2. #22
    I've slid my blocks on to the rails and removed them multiple times while setting up, using the plastic retainer pushed against the end of the rail each time. No problems so far, although I just know I'm going to have a wobble some time...
  3. #23
    cut the rails to length and slipped on 2 blocks this afternoon... don't know what I was worried about
    I assume these are double seals?
    is it worth adding the scraper? I assume it is just a case of unbolting the existing seal & slipping it on?
Name:	2015-02-18 16.19.27.jpg
  4. #24
    wow cant believe it has been so long since I last posted
    progress is slow but steady, various bits & pieces required to complete the x axis frame are now machined except for about a dozen holes... as usual for me... I keep forgetting to take pictures, not that a pile of aluminium plate machined & drilled is terribly interesting
    progress has not been as linear or as logical as I would have done myself, as I am working on bits I have while designing stuff like the base frame and control box... normally I would do all the design then start from the ground up...
    so... mocking up the bearing carriage for the x axis, the wooden block was made as a model to see how the clearances worked out and to visualise the ballnut mounting method, as I could not see the wood for the trees in cad. once assembled the mounting for the ballnut is obvious immediately. working in wood is an easy and cheap way to prototype parts, the block of 6082 this will be machined from is about £100 and will take the best part of a day to machine so cant afford many mistakes
    final design..
ID:	14874   Click image for larger version.
ID:	14875   Click image for larger version.
Name:	bearing carrage and ballnut.jpg
ID:	14880   Click image for larger version.
Name:	gantry riser2.jpg
ID:	14879   Click image for larger version.
Name:	gantry riser.jpg
  5. #25
    gantry risers are finished... ready for trial assembly
    upside down but shows how the top plates interlock with the gantry rail to help with alignment
    detail
ID:	14883   Click image for larger version.
ID:	14882   Click image for larger version.
  6. The Following User Says Thank You to mike os For This Useful Post:
  7. #26
    Pics look great. G.
  8. #27
    bit more progress, x axis is hopefully "finished" ie only needs minor changes like limit switches and guarding fitting.... and base frame is made, so I can start a trial assembly soon
Name:	2015-04-02 15.37.08.jpg
ID:	15094   Click image for larger version.
Name:	2015-04-02 11.57.51.jpg
  9. The Following User Says Thank You to mike os For This Useful Post:
  10. #28
    x axis on its stand, square and levelled..
    bearing carriage machining...
    and one finished
    both now done... bit of aping & counterboring then I can start assembling the gantry
Name:	2015-04-23 14.46.00.jpg
ID:	15199   Click image for larger version.
Name:	2015-04-16 10.07.56.jpg
ID:	15200   Click image for larger version.
Name:	2015-04-09 16.21.50.jpg
  11. #29
    Progress is finally being made
    Ballnut, 32mm, housing and bearing carriage ready to fit
    little vid of axis testing
    runs very smooth
Name:	2015-05-19 09.55.51.jpg
  12. The Following User Says Thank You to mike os For This Useful Post:
  13. #30
    Looking good, thanks for sharing!
  1. Router build
    Last Post: 18-12-2014, 07:19 PM
  2. Does anyone want to build me a cnc router?
  4. BUILD LOG: My Router Build!
    By andy0202 in forum DIY Router Build Logs
    Last Post: 31-01-2013, 08:51 AM
  5. BUILD LOG: A3 Router Build
