Thread: Chinese 40W Laser vs. Plexiglas
18-01-2015 #1
Hello,
I randomly bump into various sale ads for the Chinese so called 40W laser (various reports indicate it into the 30ish W range upon measurements). If somebody owns one already, what is the thickest plexiglas it can cut (multiple passes including). While we are on it, it would be interesting what other difficult cuts it can achieve, such as what is the thickest MDF or plywood it can cut?
Perspex/plexiglass like a hot knife through butter, it obligingly vapourises, the DOC depends on your rate of cut, it is the material these things are designed for.
MDF, plywood, terrible idea. Thick smoke trying to coat your lens in resinous black tar and requiring a forced air draught to disperse and extract it asap.
18-01-2015 #3
Well, what is the thickest plexiglas you managed to cut?
19-01-2015 #4
I have cut 10 mm perspex with a 40w laser. I had to do it in two passes. I would suggest a max thickness of 6mm for a 30w laser.
CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
19-01-2015 #5
That is good to hear, I didn't expect it to go through more then 3-4mm of plexiglas. Just to make sure, you are talking about the cheap 3020 chinese 40W laser, or some brand name 40W laser?
19-01-2015 #6
Mine is a diy effort with a cheap Chinese 40w tube. Remember that the thicker you cut the worse the kerf becomes. At 10 mm it starts to become quite evident.
ADD ME ON FACEBOOKS
19-01-2015 #7
Can you find some photos of how bad it looks on your cuts at 10mm?
Also, for the second pass, did you have to adjust the Z, or same height? The cheap 3020 I am talking about has no Z axis or adjustment - you have to raise the material instead, by shimming it, makign you loose the workpiece alignment.
01-02-2015 #8
Need your brains guys!!
I have a basic Chinese laser. 40w and runs from moshidraw. I'm willing to pay well anyone that can come and get it working properly. let me know if you can help. I live in Buxton, Derbyshire
Chinese tooling
By racerbear02 in forum Woodwork DiscussionReplies: 9Last Post: 09-09-2020, 12:41 PM -
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM -
new laser
By mike techserv in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 06-06-2009, 02:17 PM
