The most common configuration for a gantry is the L shape. Mostly others use either 80x40, 90x40 extrusion or 100x50 rectangular box section aluminium. There are any number of threads showing this examples such as any of Kingcreaky's 3 builds, Eddy Current's build etc. etc. have a look at these and you'll see the type of thing.
05-02-2015 #2
Hi, what do you think of this brother?
05-02-2015 #3
What Z axis height /work piece/ you are trying to achieve? The gantry seems too high, not sure, may be the perspective on the drawing. For this type of machine 100mm is reasonable, 120mm is best compromise, 150mm is on the limit and more than that is just wishful thinking. Without further reinforcing the gantry with say - a steel plate.
05-02-2015 #4
Hi yeah I think you are right it does look way too high, I have reduced it by 100mm which would look like this now :
changed to perspective projection that might look more realistic I hope.
I was really hoping to achieve more than 100mm z-height, but if I can stretch it to 150mm I guess that would be okay.
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
Newbie CNC Build
By JunkieHobbo in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 13-04-2012, 07:41 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM
