09-04-2015 #11
Exactly thats what i meant. Thanks!
There must be many ways to do a thing but here is how i think:
-more or less center to center around 90mm, so that usually the belt is in the region of 270 to 315mm depending on the ratio.
-Dont have the time now to play and prove it but at that distance/look at the Nema 23 mount/ was possible to lower the small pulley teeth count and rise the other , so as i remember 1:1 to 1:2 was possible may be even more, without changing anything. I just remember that when doing the yellow machine there was that consideration also.
Same with the servo machine now i am building but not to such extend, due to shorter play possibility.
Below you will see a picture with the maximum movement according to me and having in mind the parts were laser cut from steel. So maybe from aluminum could be more play.
Nothing to prove with all that , just sharing for your consideration and if possible to help avoiding errors. Thanks
PS. The measures are radiuses, possible play and size of the thinnest part there
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
Newbie CNC Build
By JunkieHobbo in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 13-04-2012, 07:41 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM
