    I like driving through belts because it saves trying to line things up. However if you simply bolt the motor to then end of the screw and do not care how much it wobbles and twists, all you have to do is stop it turning and you can have a much better connection than you could possibly get through an expensive coupling :D
    Thanks guys will consider the suggestions.
    now all i have remaining to machine is the motor plates, any advise on the designs ? the motor screw holes are not in correct position so please ignore that.
Name:	Z Assembly.jpg
ID:	15662   Click image for larger version.
Name:	Gantry Assembly.jpg
    Looking really good, well done.
    Be aware that if you turn a stepper using a drill it will generate power (like an alternator or generator). If it is connected to the stepper driver board this can be a bad idea!
    For motor mounting plates you need to have slots not holes so you can tension the belt. 20mm or so slot is a good start but you'll need to decide based on the standard belt lengths available and making sure you can tension it. There are some online belt length calculators available so make sure you use those and place the centre of the slot in the nominal position.
    The motor plates are usually pocketed with the motor set into the plate allowing the drive belt to run free over the top surface. You've got the motor sitting flush with the rear surface so you are having to cut all the material away in the middle to allow the belt to run. Not saying your way won't work but its usually done the other way to keep some strength in the bracket.
    okay great I'll start working on that but if my plate is 20mm thick, the pocket depth would eat up the shaft length, so is it acceptable to have the pocket area maybe 10mm thick only for example?
    Lives in Marple Stockport, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Noplace View Post
    Yes you only need a few mm to mount the motor. ..Clive
Name:	Z motor mount.JPG
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. BUILD LOG: New Build - For Your Amusement - MK-2 build
  3. Newbie CNC Build
    By JunkieHobbo in forum Gantry/Router Machines & Building
    Last Post: 13-04-2012, 07:41 PM
  4. BUILD LOG: Newbie First Build 3000mm x 1500mm
    By psiron in forum DIY Router Build Logs
    Last Post: 16-07-2010, 11:02 AM
  5. BUILD LOG: Newbie First Build
    By Dr Snuggles in forum DIY Router Build Logs
    Last Post: 10-01-2010, 07:05 PM
