06-07-2015 #10
one of the local workshops made it for me, will test and cross fingers and hopefully no more stress on ballscrews.
on a separate note, back to the spindle I have tested it and seems to be working well with the relays and mach3, the speed is not being controlled accurately and I suspect the spindle pulley setting in mach3 but still didn't figure it out, ill post a video of this issue soon.
but main thing about spindle is I ordered and received a braking resistor, its 200W 70Ohm as per the spec in the document. I know it's not needed but thought what the hell, I just have to revert the P14 setting the sylveski mentioned earlier and I think all the other default settings are good. if anyone wants to advice on this part please let me know.
thanks!Last edited by Noplace; 06-07-2015 at 10:04 PM.
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
Newbie CNC Build
By JunkieHobbo in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 13-04-2012, 07:41 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM
