  1. #23
    Quote Originally Posted by Noplace View Post
    Sorry updated the original post, it was a 4 flute cutter. I just used an online g-code generator to generate cutting a hole, it goes down 3mm depth at a time and makes it a circle path. I'm already using hsmexpress so I'll do the toolpath on that next time and see.
    Try a two flute cutter at about 14K with a pocket tool path
  2. The Following User Says Thank You to Clive S For This Useful Post:
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. BUILD LOG: New Build - For Your Amusement - MK-2 build
  3. Newbie CNC Build
    By JunkieHobbo in forum Gantry/Router Machines & Building
    Last Post: 13-04-2012, 07:41 PM
  4. BUILD LOG: Newbie First Build 3000mm x 1500mm
    By psiron in forum DIY Router Build Logs
    Last Post: 16-07-2010, 11:02 AM
  5. BUILD LOG: Newbie First Build
    By Dr Snuggles in forum DIY Router Build Logs
    Last Post: 10-01-2010, 07:05 PM
