Yes. You would have to spin the ballscrew twice as fast as a 1610 to achieve the same linear speed
Sent from my XT1072 using Tapatalk
08-11-2015 #2
08-11-2015 #3
If you take the belt off the Z-axis and give it a slight push, does it start moving down by itself due to gravity? If not then your ballscrew and or rails may not be aligned well.
To increase the acceleration capability the easiest way is to change the drive ratio. Make the pulley on the Z ballscrew larger, or the motor pulley smaller. The torque required for acceleration is proportional to the inertia reflected to the motor. This inertia scales with the drive ratio squared, so if you make the ballscrew pulley half the size, the motor will see about 1/4 of the inertia as before and the torque goes down by the same ratio. It's not quite as good as that as the larger diameter pulley will have a higher inertia, but you'll also reduce the torque required due to friction and lifting the axis (though that is already small).
Once you think the motor tuning is correct, I recommend running random g-code rapid moves for say half an hour, as that will stress the system to give confidence that the machine will not stall. I've made a spreadsheet here to do it:
http://www.mycncuk.com/threads/5843-...g-motor-tuning
The Following 2 Users Say Thank You to Jonathan For This Useful Post:
05-02-2016 #4
Guys quick question, filling up the steel tubes, is it worth it? can I use normal concrete for that? any disadvantages?
05-02-2016 #5
05-02-2016 #6
05-02-2016 #7
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
Newbie CNC Build
By JunkieHobbo in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 13-04-2012, 07:41 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM
