08-11-2015 #121
08-11-2015 #122
But because the motor is spinning faster it will have less torque than the same motors in the other axis
Sent from my XT1072 using Tapatalk
The Following User Says Thank You to CharlieRam For This Useful Post:
08-11-2015 #123
08-11-2015 #124
If you take the belt off the Z-axis and give it a slight push, does it start moving down by itself due to gravity? If not then your ballscrew and or rails may not be aligned well.
To increase the acceleration capability the easiest way is to change the drive ratio. Make the pulley on the Z ballscrew larger, or the motor pulley smaller. The torque required for acceleration is proportional to the inertia reflected to the motor. This inertia scales with the drive ratio squared, so if you make the ballscrew pulley half the size, the motor will see about 1/4 of the inertia as before and the torque goes down by the same ratio. It's not quite as good as that as the larger diameter pulley will have a higher inertia, but you'll also reduce the torque required due to friction and lifting the axis (though that is already small).
Once you think the motor tuning is correct, I recommend running random g-code rapid moves for say half an hour, as that will stress the system to give confidence that the machine will not stall. I've made a spreadsheet here to do it:
http://www.mycncuk.com/threads/5843-...g-motor-tuning
The Following 2 Users Say Thank You to Jonathan For This Useful Post:
05-02-2016 #125
Guys quick question, filling up the steel tubes, is it worth it? can I use normal concrete for that? any disadvantages?
05-02-2016 #126
I think kiln dried sand (as used for block paving) is the preferred thing to fill with for resonance. That way if you put bungs in you can empty it should you wish to move the machine...
The Following User Says Thank You to njhussey For This Useful Post:
05-02-2016 #127
05-02-2016 #128
Neil is correct, problem with creat is it can become brittle and brake up/crack, when that happens you end up with "lose" in your tubes and so on.
We used to call it silver sand back in my paving/block driveway days, think there is a difference between it and kiln dried, silver being a finer grade as it needs to work it's way into all the joints on the blocks.
.MeLee
The Following User Says Thank You to Lee Roberts For This Useful Post:
05-02-2016 #129
05-02-2016 #130
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
Newbie CNC Build
By JunkieHobbo in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 13-04-2012, 07:41 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM
