25-08-2015 #20
Update:
had issue with my Z motor turned out the cable had some issue so I just cut one side and directly connected it to the driver instead of the 4-pin plugs setup, works fine now.
assembled everything and tested and so far satisfied, still I got a long way to get it right:
things need to be done:
-Spindle speed control via mach3 : had issue before of speed being off, probably needed adjustment of the voltage or something.
-limit switches : using software limit only at the moment
-checking alignment/parallel via DTI : to be honest I have no training on using this properly and feel like my machine doesn't have room to adjust correctly, however I can live with a little bit of error for now, as long as the thing works!
-making triangular support legs with leveling: something I missed was to make the frame have adjustable height on each corner, now am thinking of just mounting extra 4 pieces on each corner of the frame and have those lift the whole thing up and balance accordingly
-Drag chain attached to frame : again my stupid and impulsive attitude prevented me from designing a side where drag chain can sit so I have to think about manually drilling and just attaching a flat panel so it can sit on it, no big deal I guess for now.
-Double check tension of belts : again no formal training so no idea how to do it properly but by feel I think I got it decent tension
-Connect water cooling to spindle
-Cable management of Z axis
-Actually cut something : will probably try wood(MDF) first, then maybe try my luck with other material and ultimately aluminium, anyone wanna recommend speeds and feeds for me?
-and many more I'm sure, hope I get some positive feedback from you guys in order to make it better!
A quick photo of the machine:
Video of axis movement , before mounting spindle( at time of this post it is still uploading but give me 20mins or so plz hehe)
am sure u guys might have some comments, particularly on sound of long axis movement, had lots of issues with it being flexing/bending if I tighten the gantry too much or so, the ballscrew ends might need shimming but not sure how to approach it yet.
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
Newbie CNC Build
By JunkieHobbo in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 13-04-2012, 07:41 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM
