05-02-2016 #36
Neil is correct, problem with creat is it can become brittle and brake up/crack, when that happens you end up with "lose" in your tubes and so on.
We used to call it silver sand back in my paving/block driveway days, think there is a difference between it and kiln dried, silver being a finer grade as it needs to work it's way into all the joints on the blocks.
.MeLee
The Following User Says Thank You to Lee Roberts For This Useful Post:
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
Newbie CNC Build
By JunkieHobbo in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 13-04-2012, 07:41 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM
