05-02-2016 #2
07-02-2016 #3
I see epoxy granite is mentioned a lot also online, what do you think of it? also do you have an example of a cement product for table tops/workshop floors so that I can check locally whats available?
EDIT: also what about UHPC, I highly prefer something that would be permanent instead of grain/sand structure that's why I'm asking about these options instead. thanks!Last edited by Noplace; 07-02-2016 at 12:28 PM.
07-02-2016 #4
Yes but the steel in bridges is normally reinforcing and therefore encased in concrete so no air can get to it, if done properly that is! Here we're talking about encasing concrete with steel, there's got to be a hole in to pour the concrete (and for air to escape) and therefore there's a way for air to get in. Now if you could pour it in a vacuum......
07-02-2016 #5
07-02-2016 #6
...or the bridge is built from Cor-Ten steel which is allowed to weather and build up a rust-based patina that coats the surface and prevents further corrosion. Not many routers built of that, though!
20-04-2016 #7
Hi all, some updates, most of my free time these past months I spent on cosmetics, reassembling, cable management etc and putting the enclosure since I moved to a new room which is dedicated for this machine.
here is a photo of the machine and some acrylic cuts which were the first actual project which I made for a friend of mine.
Today I tried to face an aluminum plate ( looks funny I know, all I have at the moment hehe ) which I intend on using as a fixture for metal works. this is 6000RPM and 2 flute 1/2 cutter with 1200mm/min feed , based on sound please let me know your opinion and if you have recommended settings, I tried a fly cutter before and the results werent as smooth as this endmill. does mach3 have a wizard to generate facing operation G-code, would save me time instead of manually entering G1 commands hehe while holding the camera
All in all I'm satisfied and feel fortunate to have learned what I needed to accomplish this, but I wish if I could go back in time and design a better machine with automatic tool changing. wish I had formal education in mechanical engineering and machining so I could achieve better accuracy in the design,machining parts and assembly. but alas I guess that could be a future project.Last edited by Noplace; 20-04-2016 at 06:07 PM.
20-04-2016 #8
21-04-2016 #9
wow that looks aggresive, never imagined I would attempt it at this high RPM! thanks I will give it a shot with the flood coolant
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
Newbie CNC Build
By JunkieHobbo in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 13-04-2012, 07:41 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM
