    Great machine!
    What about that. Or second, if you don't feel like digging 9mm into aluminum but just 3mm
ID:	18251Click image for larger version.
    PS. With a strong cooling i mean
    wow that looks aggresive, never imagined I would attempt it at this high RPM! thanks I will give it a shot with the flood coolant
    last year I bought this indexable cutter http://www.rdgtools.co.uk/cgi-bin/ss...2309&NOLOGIN=1
    and just tried it and its giving a much better finish, downloaded HSMAdvisor trial and for this cutter its giving me low RPM for HSS and very high for Carbide, any idea how to identify if the triangle insert is Carbide or not, all it says its Tin coated, not sure what the other abbreviations are
    this is a set of them from same site, for reference http://www.rdgtools.co.uk/acatalog/1...3.html#SID=404
    alternatively any recommendations to replace it with a carbide one in case those are not?
    Those are carbide inserts. Replaceable inserts like those come in different grades of carbide and with different geometry (tip radius, for example) but they are all carbide. Never seen an HSS insert, although someone somewhere probably makes them.
    They are carbide inserts right, but i think they should not be treated like a normal carbide cutter. Instead an indexable mill tool should be found in the database and edited correctly.
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. BUILD LOG: New Build - For Your Amusement - MK-2 build
  3. Newbie CNC Build
    By JunkieHobbo in forum Gantry/Router Machines & Building
    Last Post: 13-04-2012, 07:41 PM
  4. BUILD LOG: Newbie First Build 3000mm x 1500mm
    By psiron in forum DIY Router Build Logs
    Last Post: 16-07-2010, 11:02 AM
  5. BUILD LOG: Newbie First Build
    By Dr Snuggles in forum DIY Router Build Logs
    Last Post: 10-01-2010, 07:05 PM
