  1. #2
    First of all are you sure the Vectric software you have cannot do this ?
    When you get it loaded into Rhino it will look like the yellow object you show above.
    Click on empty space in the top right window (perspective) then click on the dropdown arrow beside the word Perspective and click on 'Rendered'
    It should now look like it does in Vectric.
    Using the text tool write some text and posion it so it's above the stl object, make sure it will fit, don't let it overlap into space.
    Now select the stl object so it turns yellow and select 'Project' from the menu;
    Now select the text you want to project and press Enter, you should end up like this;
    If not then look on YouTube or the web for instruction on Curve Project
  1. Fine detail Wood.
    By Leadhead in forum Wood Finishing Tips & Tricks
    Last Post: 18-02-2017, 04:36 PM
  2. Need some help and advice, ideas for finishing a detail
    By Boyan Silyavski in forum Metalwork Discussion
    Last Post: 09-12-2014, 04:05 PM
  3. File upload problems - attachments file extension support !
    By Swarfing in forum General Discussion
    Last Post: 08-03-2013, 02:37 PM
  4. Imported L298 Arduino Modules
    By boldford in forum Motor Drivers & Controllers
    Last Post: 30-07-2012, 11:06 PM
