It's got a single screw and also a single carriage (which is what I think crazydiamond was looking at) on the X axis rails which I guess could be OK for a plasma/laser but not OK for anything else. I wouldn't be too concerned with the non branded rails if this was for DIY home use and not for commercial use as by the time they've worn to any extent that is becoming noticable (assuming that the build has been put together so there's not undue stress on the bearing to start with) the OP will be an OAP (if they're not already
What are you looking to use the machnie for Dwayne Dibbley?
05-02-2015 #2
Hi, i was after some ideas to build a machine approx 3'x2' with the ability to machine aluminium along with MDF acrylic etc. Only saw this design as it looked fairly easy to build using the ali extrusion with some mods. But maybe it will still be too flimsy for my needs ( only home diy ).
Some thoughts on cnc machine design principles. . .
By routercnc in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 09-10-2020, 10:59 AM -
Setup for squaring twin X-axis gantry
By routercnc in forum Gantry/Router Machines & BuildingReplies: 20Last Post: 26-03-2014, 11:13 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM -
Gantry design question
By D.C. in forum Gantry/Router Machines & BuildingReplies: 30Last Post: 10-10-2012, 09:11 AM -
Router design thoughts
By m_c in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 11-09-2012, 07:06 PM
