Thread: 8 x 4 sheet capability
19-02-2015 #1
If i require the machine to work on 8 x 4 sheets, what is the way to determine how big the bed should be, allowing clearances for board run off and router head position/offset?
Many thanks
Phil
19-02-2015 #2
Hi, I'd draw a quick sketch of your proposed machine and see that way. It's a bit like saying how longs a piece of string really...it depends on bearing spacing on your machine's X, Y and Z axis as to how big you need the bed.
19-02-2015 #3
The actual table top is usually the size of the sheet.
But, I'd allow for the tool to reach 25-50mm past the sheet on all sides, and then add your bearing spacing. This is the minimum length of your rails.Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
19-02-2015 #4
20-02-2015 #5
21-02-2015 #6
Jazz, I did not mean to complicate or confuse, I was only adding to Ger21's post. G.
21-02-2015 #7
22-02-2015 #8
24-02-2015 #9
I presume you've checked this thread out? http://www.mycncuk.com/threads/8242-...ght-ply-cutter I'm sure if you ask Matt nicely he'll tell you what size his machine ended up.
How to cnc cut 1-2mm stainless sheet ??
By Ricardoco in forum Metalwork DiscussionReplies: 9Last Post: 28-03-2013, 04:06 AM -
THC lifting off sheet?
By lockyg in forum Machine DiscussionReplies: 2Last Post: 06-12-2012, 04:56 PM -
3mm sheet brass
By cropwell in forum Marketplace DiscussionReplies: 1Last Post: 17-10-2012, 09:55 AM -
RFQ: small, primitive Press with cutting and bending capability
By Noel.C in forum Projects, Jobs & RequestsReplies: 15Last Post: 29-05-2012, 11:37 PM -
Mini Lathes and their capability
By GeorgeD in forum Lathes, Lathe Rebuilding & ConversionsReplies: 8Last Post: 02-08-2010, 05:29 PM
