03-02-2015 #1
Hi Guys
In need of some help please I have been running my CNC machine using NCStudio for about 6 months now and its come the time to upgrade to Mach3 so purchased Breakout board CNC Stepper Motor 5 Axis Spindle Relay HG08 from CNC4You with Mach3 software and was offered surport with any issue or help need so far that been like pulling teeth painfull at times.
So far I know which wires are the Pulse and Direction wires for X, Y, and Z on the machine.
We would like to know what are the corresponding terminals on the HG08 breakout board.
At a guess I'd say it was the...........
Blue wire is PULSE- and should connect to CK on the HG08
Green wire is DIR- and should connect to CW on the HG08
Can anyone help with advice my machine is down at the moment and its killing me any help would be great and thank you in advance
George
03-02-2015 #2
Page 5 shows the diagram, what you suggest is correct however I can't confirm the wire colours.
http://cnc4you.co.uk/resources/Break...ard%20HG08.pdfLast edited by EddyCurrent; 03-02-2015 at 11:44 AM.
The Following User Says Thank You to EddyCurrent For This Useful Post:
03-02-2015 #3
03-02-2015 #4
I looked at the top common anode diagram and put a link to the manual.
04-02-2015 #5
04-02-2015 #6
Hi edddy
The board has a 5v point with 2 connection points mark with yellow dot in the picture I have established what I think is the 5V wire which was connected to the NCstudio board and marked 5v. Not sure which of the two points to connect this to on the HG08 board ? any help.
04-02-2015 #7
Well the ones with the yellow dot are the power input and according to the manual it should be 7 to 55 volts, so 5v is no good, I would suggest a 24v supply.
Here's the wiring diagram; http://cnc4you.co.uk/resources/CW504...%20Diagram.pdfLast edited by EddyCurrent; 04-02-2015 at 08:48 PM.
05-02-2015 #8
5v supplies for breakout board
By dazza in forum General ElectronicsReplies: 17Last Post: 17-12-2014, 09:44 AM -
Breakout Board
By Tomnewry in forum General ElectronicsReplies: 2Last Post: 12-12-2013, 07:24 PM -
Stepper Driver / PSU / Breakout board Wiring ?
By manofgresley in forum General ElectronicsReplies: 2Last Post: 16-08-2012, 05:41 PM -
FOR SALE: PMDX-122 Breakout board
By IN-WondeR in forum Items For SaleReplies: 0Last Post: 14-12-2011, 04:05 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM
