Yeah I didn't explain that very well.
Say you have
G1 X10 Y10 Z0
G2 X20 R5 Z10
It will go smoothly from Z0 to Z10 along the length of the arc, so half way through it will be at Z5. Same as if you do
G1 X0 Y0
G1 X10 Y10
It won't do all the X movement and then all the Y movement, it will smoothly move between the two points.
Going down the correct path, Amadeal AMD25LV mill conversion to CNC
By StevenT in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 20-07-2014, 08:23 AM -
Relationship between Guide rail length and ballscrew length
By CharlieRam in forum Rails, Guideways & BearingsReplies: 6Last Post: 11-07-2014, 11:37 PM -
Romi EZ-Path S Lathe crt replacement
By Nemo1966 in forum MonitorsReplies: 5Last Post: 07-10-2013, 04:25 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
in calculating the tool path
By Grumpy Mike in forum Programmers CornerReplies: 17Last Post: 31-07-2010, 10:18 AM
