Okay - I see now, the Z is 'dropping' from its previous value as it draws the arc.
Cheers Rufe0 - I'm sure that this'll come in handy, even if it's a springboard into looking at a bit more G-code, which I really ought to.
Wal.
17-11-2015 #2
If you must use program generated code I made this little program that might help you. Copy in only the shape you need altering. All it does is add Z depth onto the end of every line.
Download and rename the file ProgramForWal.html and open in your web browser.
17-11-2015 #3
Hey man, that's awesome. Thanks a lot for that..!
Just heading back home to have a closer look at it. Thanks again.
Wal.
17-11-2015 #4
Fixed a few little things and added a new feature, it's possible todo any number of down ups.
The Following User Says Thank You to Rufe0 For This Useful Post:
18-11-2015 #5
Hi Rufe0,
Very cool - I'm always blown away by the skills of programmers. Just amazing. I have a couple of observations, although I'm pretty certain you'll be aware of 'em. When using the script on a rounded rectangle, there's a more pronounced drop on the 'rounded' segments due to the extra lines of Cut 2D code that are forcing extra incremental drops in the Z-axis:
The next pic shows that despite asking for a drop of 20 on this square, the Z only drops to 14.44, other shapes have dropped the specified amount, so perhaps this is an incompatibility between your script and the way Cut 2D formats it's code when dealing with different shapes..?
Hey, but seriously - I'm really impressed and very grateful to you for taking the time to help me out..!
Wal.
18-11-2015 #6
Fixed a few little bugs in V2.2
Yeah thats the problem with just addind a Z on the end of every line. Todo it properly it would need to read every line, figure out how long the move is and then adjust the Z accordingly. That would be alot more work... but i'll think about it.
Originally Posted by Wal
18-11-2015 #7
Going down the correct path, Amadeal AMD25LV mill conversion to CNC
By StevenT in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 20-07-2014, 08:23 AM -
Relationship between Guide rail length and ballscrew length
By CharlieRam in forum Rails, Guideways & BearingsReplies: 6Last Post: 11-07-2014, 11:37 PM -
Romi EZ-Path S Lathe crt replacement
By Nemo1966 in forum MonitorsReplies: 5Last Post: 07-10-2013, 04:25 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
in calculating the tool path
By Grumpy Mike in forum Programmers CornerReplies: 17Last Post: 31-07-2010, 10:18 AM
