Thread: stepper with DIY type controller
how hard is it to make your own driver to run say a nema 17 size stepper that has a potentiometer to drive it ?
10-02-2015 #2
You mean like this http://www.dx.com/p/jtron-speed-reve...Q#.VNnr7E0pUdU
I recently used a power supply and microstepping driver, combined with arduino and thumbstick/joystick (which is basically potentiometer) to control two Nema 23's for both axis on my lathe. Its far from elegant but does work.
Its a temp soltuion whilst i source a pc/laptop with parallel port.
Code for arduino is relatively simple as is the wiring.
Is this the kind of thing your on about doing??
You may infact be able to just use an arduino and a "motor sheild" if its Nema 17's.
11-02-2015 #4
http://www.cognisys-inc.com/products.../stackshot.php
i would like to build something like that, it doesnt have to have all the bells and whistles but a basic move x trigger shutter move x again and repeat
11-02-2015 #5
I am sure this could be done with an Arduino and a display http://www.ebay.co.uk/itm/New-Blue-I...-/271634672688 using a simple driver http://www.ebay.co.uk/itm/L298N-Step...item43d12bba8a ..Clive
11-02-2015 #6
This is something i have considered, any use ?
http://www.minie.airiclenz.com/hardw...ware-minie-v2/
There is a shop to buy the bits and you just need a Arduino and a couple of stepper motor drivers.
Best type of shed.
By Philly in forum General DiscussionReplies: 14Last Post: 03-11-2018, 08:17 PM -
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
Stepper controller to manually input a specific degree
By Web Goblin in forum Motor Drivers & ControllersReplies: 11Last Post: 13-10-2013, 05:47 AM -
How can I find fast stepper motor / controller combo?
By JuKu in forum Stepper & Servo MotorsReplies: 2Last Post: 23-07-2013, 12:32 PM -
What type of resistor?
By Smiler in forum General ElectronicsReplies: 4Last Post: 05-12-2008, 10:04 PM
