  1. #14
    I will most probably go with the CSMIO/IP-A.
    IP-A is perfect control and very easy to do this using the encoder index pulse. See manual how to do it.
    And an input called 'Zero clamp' I have no idea what it is for.
    Are these brushed DC servo's.? if so then be careful as the encoders are probably single ended and not differential which the IP-A requires.
    Is it safe to use only one switch on each axis side for both soft limit and home?
    Soft limits doesn't use switches it's exactly that limits set in software so no switches involved. It's safe to use shared limit and home switches if your stuck for room or inputs but with so many i/o why.?
  1. Advice on a charge controller please :)
    By blackburn mark in forum General Electronics
    Last Post: 04-05-2020, 07:28 PM
  2. Advice please! JAF Motion Controller issues!
    By Mark Chard in forum Machine Control Software
    Last Post: 31-01-2014, 05:03 PM
  3. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
  4. Which controller and motors? Newbie advice please
    By Nealieboyee in forum Motor Drivers & Controllers
    Last Post: 16-10-2012, 02:56 PM
  5. Purelogic Tiny Mach3 USB motion controller PLCM-LPT2
    Last Post: 21-08-2012, 08:22 AM
