31-12-2014 #1
I have a 3 axis CNC USB bob 200khz like this one :
http://www.ebay.co.uk/itm/2517477394...480%26_rdc%3D1
There are also available this card :
http://www.ebay.co.uk/itm/2611636890...018%26_rdc%3D1
As far as I can see, the only difference between the two boards, is on the 3 axis board there are two Optocouplers missed out for the 4th axis. I have emailed several companies supplying this board and they say they are completely different designs. I doubt that. I have ordered two Optocouplers of the same as the others to see if I can control a 4th axis. There are outputs on the end of the board for the 4th axis if you look. The IC's cost me a grand total of 3 EurosLast edited by dudz; 31-12-2014 at 01:01 PM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
FOR SALE: leewood 3 axis controller from an isel 3 axis cnc
By nobby in forum Items For SaleReplies: 1Last Post: 24-09-2014, 09:08 AM -
Fix engrave vertical gap or Upgrading laser cutter control card Leetro MPC6515 ?
By Paul Shroom in forum Machine DiscussionReplies: 3Last Post: 18-05-2014, 03:40 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM -
WANTED: Need electronics, anyone upgrading??
By fasteddy in forum Items WantedReplies: 2Last Post: 25-09-2009, 06:46 AM
