11-02-2015 #4
Ok paul on the RH hanger very simple way is to just delete the last operation in feature manager tree.
So delete Body-Delete operation or drag the blue bar up above it which will take you back one step.
Then if you want make a mirror with some separation between the parts create a Plane parallel to the edge your mirroring from and set a offset distance. Then use mirror function and select bodies to mirror option and click on part then uncheck Merge solids.
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
By ali hedi in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 06-07-2011, 11:58 PM -
extrusion construction
By CNCBlug in forum General DiscussionReplies: 12Last Post: 03-01-2010, 12:13 AM
