Hi everyone,
So I just got myself a serial port pcie card and connected it to one of my EM806 to see what the protuner software offers. I'm glad it finally worked after million tries with a usb-serial cable
 but now I'm not sure how to properly tune everything and how to select the microstep and current. should the current be the same as indicated in zappautomation site? I'm supplying around 60v so I think it should be 4.3A as per the stepper motor page but I'm not sure. there is a guide for resonance as well but I didn't go through with it yet.
and btw should I wait until I finish my build and actually connect the motors to mechanical parts before doing any tuning?
	17-02-2015 #2
The Following User Says Thank You to EddyCurrent For This Useful Post:
	17-02-2015 #3
Thanks I just saw your reply here http://www.mycncuk.com/threads/7946-...Nema-23-Tuning and got most of the answers, but I still wonder whats the best current is, the motor says 4.2A for the parallel connection I'm using, on leadshine EM806 site it mentions the peak and RMS current for each setting, which one should I consider? can the peak be higher than 4.2A if RMS is below?
thanks
	17-02-2015 #4
I find the information here useful; http://www.geckodrive.com/support.html most of it applies to any system not just Gecko.
and here; http://www.amci.com/tutorials/tutori...ak-current.asp
I would use the RMS value and set it to the same or nearest value below. For example if the motor was 4.2A RMS and the settings on your driver were, RMS 3.5, 4.0, 4.5, then I would choose 4.0 on the driver.Last edited by EddyCurrent; 17-02-2015 at 12:12 PM.
	17-02-2015 #5
Set the drives to the peak rating of the motors. 4.2A in your case. Use The tuning software for setting amps because it isn't restricted to set current amounts like the dip switches and can be adjusted in 0.1A increments.
	17-02-2015 #6
One of life's little mysteries, peak or RMS. Apparently all stepper motors are specified with RMS currents, peak current varies as microstepping is applied. At least if you use the peak value they won't overheat.
AM882 and Nema 23 Tuning
By thorphar in forum Motor Drivers & ControllersReplies: 4Last Post: 06-10-2014, 10:13 PM -
Plasma tuning speed...
By Davek0974 in forum Plasma Table MachinesReplies: 0Last Post: 12-02-2014, 10:45 AM -
Help please with motor tuning mach 3.
By Kevin1970 in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 13-06-2012, 10:22 PM -
some questions on tuning and motors
By m.marino in forum Stepper & Servo MotorsReplies: 2Last Post: 17-04-2009, 06:55 PM
