If i had to do it i would just make a drilling jig, located and secured on the two tapped holes that secure the handwheel leadscrew assembly.something nice and flat(obviously) with a couple of decent size holes on your required pitch then make two sleeves a good push fit into your base, make sleeves also for your tapping drill and your tap.
Regards
Mike
12-02-2015 #2
I have an M10 stainless repair washer with one side ground flat and mirror polished, if the drill bit in the reflection looks like it's in a straight line with the actual bit then the bit is perpendicular to the mirror surface.
I superglue the washer centered on the punch mark and have at it with a battery drill, keeping the bit and it's reflection aligned,
- Nick
13-02-2015 #3
mekanik that's a good idea and worth a try.
though i don't know how hard its going to be to drill it
il take some measurements for making the jig.
cheers.
cheers magicniner
CNC drill bit conundrum...
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 06-07-2015, 04:37 PM -
WANTED: Drill press
By D-man in forum Items WantedReplies: 0Last Post: 30-08-2013, 07:45 AM -
RFQ: Z axis and y axis carriage
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 08-04-2013, 10:06 AM -
Bearing Spacing on Y-Gantry-Carriage
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 29-10-2012, 01:16 AM -
CNC style lathe home brew Lathe for drilling and cutting.
By Bodge in forum Lathes, Lathe Rebuilding & ConversionsReplies: 9Last Post: 18-04-2012, 10:45 AM
