    hi all
    i want to drill and tap two holes in the end of the carriage
    what would be the best way to do this.
    i guess trying to drill them with the carriage on the lathe with a power drill would be hard.
    so really the best way i can think of
    would be to take the carriage off and drill on a pillar drill.....?
    and I don't have a mag drill.... unless someone close to me does.
    thoughts....
    cheers all
Name:	Lathe Slide.jpg
    If i had to do it i would just make a drilling jig, located and secured on the two tapped holes that secure the handwheel leadscrew assembly.something nice and flat(obviously) with a couple of decent size holes on your required pitch then make two sleeves a good push fit into your base, make sleeves also for your tapping drill and your tap.
    Regards
    Mike
    I have an M10 stainless repair washer with one side ground flat and mirror polished, if the drill bit in the reflection looks like it's in a straight line with the actual bit then the bit is perpendicular to the mirror surface.
    I superglue the washer centered on the punch mark and have at it with a battery drill, keeping the bit and it's reflection aligned,
    - Nick
    mekanik that's a good idea and worth a try.
    though i don't know how hard its going to be to drill it
    il take some measurements for making the jig.
    cheers.
    cheers magicniner
    When you make the sleeve for the jig plate have a reasonable size flange butting up to the plate and push it in with your vice this will make sure it's square.
    I have something in the shed if i can find it, i will try and upload a picture.
    Regards
    Mike
    Hope this makes it a bit clearer.
    Mike
  1. CNC drill bit conundrum...
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 06-07-2015, 04:37 PM
  2. WANTED: Drill press
    By D-man in forum Items Wanted
    Last Post: 30-08-2013, 07:45 AM
  3. RFQ: Z axis and y axis carriage
    By D-man in forum Projects, Jobs & Requests
    Last Post: 08-04-2013, 10:06 AM
  4. Bearing Spacing on Y-Gantry-Carriage
    By WandrinAndy in forum Gantry/Router Machines & Building
    Last Post: 29-10-2012, 01:16 AM
  5. CNC style lathe home brew Lathe for drilling and cutting.
    By Bodge in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-04-2012, 10:45 AM
