    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 619 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I am wanting to do a profile cut in Oak using a 6mm 2f HS cutter full slot. I would like an idea of the speed & feed, DOC, rpm etc. The Oak is 20mm thick. It will be cutting long grain and end grain.
    Attached Files Attached Files
    i find that oak splits easily if you use upcut, make sure you on a down cut (climb or conventional milling)
    feeds , i take it easy to avoid splinters
    3mm DOC, 3000mm feed , 12k rpm
  1. Feed and speed equation
    By Bush Flyer in forum Spindles & Drive Motors
    Last Post: 18-03-2014, 01:32 AM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. App calculator feed and speed windows phone
    By hoezap in forum Computer Software
    Last Post: 14-02-2013, 11:44 PM
  4. Chamfer Feed & Speed - G-Wizard?
    By Tenson in forum Computer Software
    Last Post: 05-02-2013, 07:01 PM
