    Ok experts and the like........My spindle head is sounding a little "Whizzy" in use. Sometimes it's there, sometimes it's not. I strongly suspect the ball races which are 7002 type.
    So, my question is ...
    Ceramic or not ?
    Any benefits or gotchas ?
    Will they withstand the occasional clamp/cutter interface etc
    Or shall I stick to plain old metal sort
    If you can't fix it with a hammer you've got an electrical problem !
    Having worked with them for a few years in my day job my advise would be If you can afford the ceramic bearings then why not. Just be sure to get the accuracy and preload class correct. Contrary to common belief, they are as tough as the hardened steel ones.
    Typically you will get the hybrid types on machines where the races are steel and the balls are silicon nitride or carbide. The balls actually condition the races somewhat and the whole system works smoother with less friction even at near dry conditions.
    Best of luck.
    Hmmmm....Preload and class. Well it's a Chinese build water cooled head. Unsure what the preloads would be but until I strip it (Work is busy at the mo and can't afford the downtime) I'll not know.
    Perhaps I'll seek out some anyway and try them out.
    Thanks for the reply
    Quote Originally Posted by komatias View Post
    Best of luck.
    Would suggest NOT going with ceramic's!
    Why?, expensive and fragile!
    A single "nock" or mishap could kill them and make it a waste of time for this application on top of it being OTT IMO.
    Replace like-4-like and you cant go wrong.
    .Me
    .Me
    Lee,
    It depends on the ceramic used. (Engineering ceramics does not mean pottery) I can personally admit to having taken a hammer to some silicon nitride and silicon carbide balls and they did not even dent.
    It all depends on what you buy.
    I know of at least one oilwell drilling tool that uses such bearings being rated to a few hundred G's worth of shock.
    One local manufacturer used to supply a machine reconditioner angular contact bearing for bridgeport type mill spindle. On my desk I have a set of angular contact bearings wheel bearings of the same brand as used on the racing Smart car made by the same company.
    Please do not take this personally, I am just going on my experience. You may of course have different experience which I think would be nice to share here.
    .Me
    Komatias..........Where would you suggest I purchase a pair of ceramic 7002s form that would be good for my spindle ?
    Lee,
    No problem and I stand informed/corrected my only experience is I once asked the same question and was given more or less the same reasponse by John Stevenson (John S).
    Ceramic is a buzz word.
    Ceramic bearing only come into play at speed we can't reach.
    Long short is crash a spindle with ceramic bearings in and they are toast, decent steel bearings which can easily stand 24,000 revs with the right lubrication can withstand a crash provided it's not monumental.
    Drop a block of steel on a tiled floor, which one comes out best ?
    So I guess it comes down to his experience with them not mine, given you've shared yours I know who ill choose to go with on it, any chance of some pics ?
    .Me
    .Me
    .Me
    Sure, I will get some this week.
    Cermic bearings do cost, but then if you go and buy any set of "precision" bearings you are bound to pay. Looking back, I purchased my steel ballscrew mounting moderate preload bearings for around the same price as I would have paid for the smart car ones. Ballscrew mounting rated ceramic ones were rather more expensive though as they had to be custom made and at the speed my screws were going to turn, it did not make sense.
    Standard 7002's can be picked up relatively cheaply but then the runout will start to become a problem. Especially if you get ones that are not ABEC preloaded, I am thinking the ones that mountainbikes use (don't ask me where, all I know is I bought some from a mountainbike retailer at a good price). I used those with a 0.1 shim to preload and even then they were slack and gross.
    For a spindle that makes money my view is to get the better value option, (performance/price).
  9. The Following 2 Users Say Thank You to komatias For This Useful Post:
  1. Replies: 9
    Last Post: 16-11-2013, 04:27 PM
  2. How to get the balls back in a ballnut?
    By Shinobiwan in forum Lead Screws, Nuts & Supports
    Last Post: 24-03-2013, 04:35 PM
  3. Balls, balls and balls
    By Swarfing in forum Marketplace Discussion
    Last Post: 21-03-2013, 08:45 PM
  4. X2 change balls crews or not?
    By Oldie45 in forum Sieg Milling Machines
    Last Post: 17-08-2011, 07:55 PM
  5. Lost my balls!!!
    By danielbriggs in forum Lead Screws, Nuts & Supports
    Last Post: 19-08-2010, 02:41 PM
