14-02-2015 #2
TPI stands for Teeth/Threads Per Inch so on a imperial lathe you would have a 4TPI leadscrew perhaps so meaning that one turn would advance the cut by 1/4 inch
Bolts are specified in tpi so an imperial bolt would be half inch by 12tpi
Metric bolts and leadscrews are measured by pitch so in similar amounts to above the lathe leadscrew would be 6mm pitch and the bolt would be 12mm x 2mm pitch
You can also have 2 start or 3...4 start leadscrews or bolts
this means on a 2 start that the pitch is doubled so the carriage will advance twice as far but there are 2 thread running concurrently..you can see the helix angle is steeper on a multistart thread
On your example i cant help you on the 8-4 bitLast edited by IanParkin; 14-02-2015 at 09:56 PM.
leadscrew conversion thoughts
By GEOFFREY in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 18-12-2012, 12:56 AM -
Leadscrew
By fusionkid in forum Lead Screws, Nuts & SupportsReplies: 23Last Post: 27-03-2011, 11:07 PM -
(Mini Lathe)Potecting Leadscrew
By GeorgeD in forum Milling Machines, Builds & ConversionsReplies: 17Last Post: 29-09-2010, 11:48 AM -
Source of multi-start ACME or Metric Trapezoidal Leadscrew and Anti Backlash Nuts
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 16-03-2010, 10:11 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
