Page 4 of 5 FirstFirst ... 2345 LastLast
  1. #31
    Quote Originally Posted by GEOFFREY View Post
    Kendrick, I do not think your spindle is DC,
    Easy to check Kendrick just take the connector off the spindle and if it as 2 wires it's DC, 3 wires it will be VFD/3phase like Geoffrey says. Looking at your other post I agree with Geoffrey it looks like VFD control panel.
  2. #32
    Fr the power problems with the usb what about a powered hub then the usb power is not coming from the laptop.
    The spindle has 4 pins coming off it more than I would expect from DC maybe brushless with a backemf sensor wire.
    kendrick
  3. #33
    Quote Originally Posted by Kendrick57 View Post
    kendrick
    See in this other thread; http://www.mycncuk.com/threads/8457-...7150#post67150 too many threads for same thing.
  4. #34
    kendrick
    Kendrick, you DO NOT have a DC spindle. G.
  5. #35
    Your Correct no point having 2 threads open for the same Cnc. This threads problems have now been sorted, can any future comments be passed to a more generalised thread about any problems I have with the 6040. Go to
    http://www.mycncuk.com/threads/8457-...7115#post67115
    kendrick
  6. #36
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    kendrick
    the 4th pin will be earth or not even connected ..Clive
  7. #37
    I have a UC300 which I've used with Mach3 and was better than just the parallel port on the PC. I now use it with UCCNC and it's another big step up from using it with Mach3. UCCNC and UC300 are designed for each other, with Mach3 you're relying on a third party plugin sitting between Mach3 and the hardware. UC300 is a good option if like me you want to add more sensors like probes and FR override control. The other advantage is you can move beyond WinXP/7 on your controller PC which when you also use it for running Vectric software is a huge advantage. Running mine on a Win10 machine and it's as happy as Larry.
  8. #38
    Can you run a UC100 with t2 laser/CNC Software? I can't get it to comunicate wih the USB on my notebook pc! Please Help.
    Thanks in advance!
  9. #39
    Quote Originally Posted by tommegna View Post
    Thanks in advance!
    It will only work with Mach3/4 or Uccnc.
  10. #40
    Thanks, I tried hard to get it to work! Would you buy Mach3 Mach4, or UCCNC Software? I would like to run it unders windows 10 ona newer P.C!
    Thanks again for your help!
    Tom Megna
  1. USB TO Parallel Port DIY Interface
    By Lee Roberts in forum Electronic Project Building
    Last Post: 17-02-2018, 07:46 PM
  2. breakout board usb or parallel
    By crossleymarko in forum Motor Drivers & Controllers
    Last Post: 30-07-2013, 12:44 PM
  3. PCI parallel card / BOB
    By artmin in forum Computer Hardware
    Last Post: 30-01-2012, 04:38 PM
  4. parallel port address
    By Dan Brown in forum Artsoft Mach (3 & 4)
    Last Post: 07-01-2010, 12:04 PM
