I have a UC300 which I've used with Mach3 and was better than just the parallel port on the PC. I now use it with UCCNC and it's another big step up from using it with Mach3. UCCNC and UC300 are designed for each other, with Mach3 you're relying on a third party plugin sitting between Mach3 and the hardware. UC300 is a good option if like me you want to add more sensors like probes and FR override control. The other advantage is you can move beyond WinXP/7 on your controller PC which when you also use it for running Vectric software is a huge advantage. Running mine on a Win10 machine and it's as happy as Larry.
USB TO Parallel Port DIY Interface
By Lee Roberts in forum Electronic Project BuildingReplies: 42Last Post: 17-02-2018, 07:46 PM -
breakout board usb or parallel
By crossleymarko in forum Motor Drivers & ControllersReplies: 13Last Post: 30-07-2013, 12:44 PM -
PCI parallel card / BOB
By artmin in forum Computer HardwareReplies: 11Last Post: 30-01-2012, 04:38 PM -
parallel port address
By Dan Brown in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 07-01-2010, 12:04 PM
