    Hi, I'd draw a quick sketch of your proposed machine and see that way. It's a bit like saying how longs a piece of string really...it depends on bearing spacing on your machine's X, Y and Z axis as to how big you need the bed.
    Neil...
    Build log...here
    The actual table top is usually the size of the sheet.
    But, I'd allow for the tool to reach 25-50mm past the sheet on all sides, and then add your bearing spacing. This is the minimum length of your rails.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Maybe consider an ATC which would require an additional area. G.
    Quote Originally Posted by GEOFFREY View Post
    Geoffrey Guy is struggling to get his head around needed cutting size don't blow is brains out by suggesting ATC. .
    Neil's suggestion of knocking a drawing up is sound advise and well worth the effort, esp if space is tight.?
    Jazz, I did not mean to complicate or confuse, I was only adding to Ger21's post. G.
    I wasn't critising you Geoffrey it was a good valid suggestion just found it funny when poor lads is still trying to workout basics and you hit him with ATC.
  1. How to cnc cut 1-2mm stainless sheet ??
    By Ricardoco in forum Metalwork Discussion
    Last Post: 28-03-2013, 04:06 AM
  2. THC lifting off sheet?
    By lockyg in forum Machine Discussion
    Last Post: 06-12-2012, 04:56 PM
  3. 3mm sheet brass
    By cropwell in forum Marketplace Discussion
    Last Post: 17-10-2012, 09:55 AM
  4. RFQ: small, primitive Press with cutting and bending capability
    By Noel.C in forum Projects, Jobs & Requests
    Last Post: 29-05-2012, 11:37 PM
  5. Mini Lathes and their capability
    By GeorgeD in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 02-08-2010, 05:29 PM
