    Charlie, CamBam has a 'join' feature too, also set your depth of cut to a negative value for Z to go down.
    Juist tried loading the your dxf and you are correct, it's in too bad a shape for CamBam to open, you could easily have drawn those in CamBam.
    Hi Clive, yes it was nice to put a face to a name after meeting you last year. Alphacam also allows you to put a box around a drawing to join and form a closed geometry, but if the break is too large it will not join them and lines/arcs need to be extended/trimmed before the join can be completed. That is what I meant when I said "cleaned up". I have never used Autocad, but suspect that most of these programs are basically very similar. For me tha advantage with Alphacam is that when a drawing is completed, the cutter paths can be put on in the same program and the G code is then automatically output and post processed to suit the machine. I like it nice and simple - I suppose that suits my mind!!! G.
    Charlie, I've attached the cb file, you need to set the depth of cut, spindle speed, feed rates, etc. The biggest tool that would do all of it was 3mm diameter so that's what I used.
    Also you're drawing was way out in no-man's-land, it's best to make drawings around the X0, Y0 position.
    Attached Files Attached Files
    Hi guys many thanks for all the help, I used auto cad to draw it as it was what I was most familiar with and I was struggling a little with drawing in cambam. I found the problem in auto cad it was some if the chamfers are not linking up for some reason but some are ( it's the ones that go from a circle to a straight line) I have generated what I think is the correct code so will try running it in some foam first and see what it does and allso compare it against what you have given me eddy ( many thanks for that much apresiated)
  5. #15
    Use PEDIT in AutoCAD To join lines and arcs into a continuous closed polyline.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  6. The Following User Says Thank You to Ger21 For This Useful Post:
  7. #16
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Thanks Gerry That's what I was looking for. ..Clive
  8. #17
    cool will try that many thanks
    I just had it cutting and all looks good however I noticed that the 3mm holes I had it does not want to do with the 3mm cutter is that because you cant go straight down only? ( this is using my file)
    many thanks
  9. #18
    Try making the holes 3.1mm and rout them out. ( might even work with 3.01mm). G.
  10. The Following User Says Thank You to GEOFFREY For This Useful Post:
  11. #19
    Quote Originally Posted by GEOFFREY View Post
    3mm works fine if using a drill mop
  12. The Following User Says Thank You to EddyCurrent For This Useful Post:
  13. #20
    I agree with Geoff make the holes 3.1mm and do them with the same endmil spiral down. ..Clive
  14. The Following User Says Thank You to Clive S For This Useful Post:
  1. Basic Frame Design
    By Ross77 in forum Machine Frames & Beds
    Last Post: 04-01-2015, 01:33 AM
  2. The ideal CNC machine for my (basic)needs?
    By mark84 in forum Machine Discussion
    Last Post: 12-03-2014, 10:56 AM
  3. NEW MEMBER: Basic 3d milling
    By proddy in forum New Member Introductions
    Last Post: 08-06-2012, 12:11 AM
  4. Advice on some basic tools
    By GTJim in forum General Discussion
    Last Post: 22-09-2011, 12:16 PM
  5. Which Basic Lathe
    By graysclassics in forum Milling Machines, Builds & Conversions
    Last Post: 06-07-2011, 10:39 PM
