Thread: very basic cad cam software
Cool cheers 40 trial sessions will be plenty
20-02-2015 #2
so I ended up drawing it in auto cad as I have used that a bit and I started to follow a you tube vid on how to load the dxf file but as soon as I try it freezes cam bam up and says invalid arc multiple times in the task bar at the bottom? any ideas?
20-02-2015 #3
21-02-2015 #4
cheers clive many thanks yes that has worked I will have to try and figure how to do that in auto cad like I say I only have very basic skills. I will now try and carry on with the tutorial.
21-02-2015 #5
I use alphacam and that uses "join", but I believe the same thing in autocad is "unite". Most other peoples DXF files that I use need to be cleaned up a bit AND JOINED to arrive at complete geometries. G.
The Following User Says Thank You to GEOFFREY For This Useful Post:
21-02-2015 #6
I think im slowly figuring it out! I think I have managed to get the g code in to mach 3 however it seams that the z axis is going the wrong way ie when it should be cutting it raising up and when its not its going down towards the table? I assume there is machine setting some were that need to be changed? I cant see anything along the top at the moment but will have another look with a fresh head tomorrow. thanks
edit just realized I needed to say - depth of cut.Last edited by charlieuk; 21-02-2015 at 01:36 AM.
21-02-2015 #7
21-02-2015 #8
Geoffrey (We met at the model show last year) Thanks. Join does work in autocad I don't think unite does. When I use autocad using join it appears to be able to join only one arc at a time (I must investigate further) but in Aspire you can just select all objects and join the lot at once. Clive
21-02-2015 #9
Charlie, CamBam has a 'join' feature too, also set your depth of cut to a negative value for Z to go down.
Juist tried loading the your dxf and you are correct, it's in too bad a shape for CamBam to open, you could easily have drawn those in CamBam.Last edited by EddyCurrent; 21-02-2015 at 10:51 AM.
21-02-2015 #10
Hi Clive, yes it was nice to put a face to a name after meeting you last year. Alphacam also allows you to put a box around a drawing to join and form a closed geometry, but if the break is too large it will not join them and lines/arcs need to be extended/trimmed before the join can be completed. That is what I meant when I said "cleaned up". I have never used Autocad, but suspect that most of these programs are basically very similar. For me tha advantage with Alphacam is that when a drawing is completed, the cutter paths can be put on in the same program and the G code is then automatically output and post processed to suit the machine. I like it nice and simple - I suppose that suits my mind!!! G.
Basic Frame Design
By Ross77 in forum Machine Frames & BedsReplies: 0Last Post: 04-01-2015, 01:33 AM -
The ideal CNC machine for my (basic)needs?
By mark84 in forum Machine DiscussionReplies: 9Last Post: 12-03-2014, 10:56 AM -
NEW MEMBER: Basic 3d milling
By proddy in forum New Member IntroductionsReplies: 3Last Post: 08-06-2012, 12:11 AM -
Advice on some basic tools
By GTJim in forum General DiscussionReplies: 10Last Post: 22-09-2011, 12:16 PM -
Which Basic Lathe
By graysclassics in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 06-07-2011, 10:39 PM
